Dane._.T
How can I generate an Induction Motor Control setup through MCSDK?
Unfortunately, I cannot get MCSDK to generate the Middleware with the Induction option, as it either does not appear (v. 6.0.0) or it fails to generate pwm_curr_fdbk.c properly (v. 5.Y.4). The other two algorithms generate fine and can run my setups. From what I've seen so far, Induction seems to be newer and is only supported in 5.Y.x.
