sshin.9
High power BLDC controller
Hello Team,
  We want to develop a BDLC driver with high power. We went through the below product, it matches other requirements except for output current, it is only up to 1.5A
Motor Control Nucleo Pack with NUCLEO-G431RB and X-NUCLEO-IHM16M1
can u suggest a similar module that can support high voltage of up to 60V and a current of up to 20A.
it should be able to operate sensored and sensorless  and also on encoder feedback.
Regards,
Sayali
    Peter BENSCH
    Peter BENSCHBest answer
    You can take a look at the EVSPIN32G4, which should fit your requirements quite well.
    Good luck!
    /Peter
    Peter BENSCH
    Good luck!
    /Peter
