Luca Zechner
Nov 27, 2018 3:42 PM UTC
HFI & X-CUBE-MCSDK
When will the HF-Injection feature be enabled for the MCSDK_v5.x.x?
I figured out, that it has been enabled in the v4.3, but in v5.2 it is only declared as "Available in a later release". Is there a possibilty to estimate a date, when this feature will be enabled?
Thanks for your answer.
Claire O.
Nov 29, 2018 10:44 AM UTC
Dear Luca,
We decided not to port the HFI in the MCSDK5.x. Indeed it works only with a limited number of motors. We are now thinking to replace HFI by a new algorithm. It will not be available before end 2019. Sorry for the inconvenience,
Best regards,
Claire
Luca Zechner
Nov 29, 2018 10:17 PM UTC
Hallo Claire,
thank you for your answer.
Ist there a other method to achieve standstill torque with the X-CUBE-MCSDK?
If it's possible sensorless.
Kind regards,
Luca
Laurent Ca...
Senior III
Jun 28, 2021 5:26 AM UTC
The question has been moved from the "Motor Control Hardware" section to the "STM32 Motor Control" section (the question is about the STM32 MC SDK).
Best regards
