Help with Reducing Power Usage in STM32F423ZHT6 Smart Lock
Hey all,
I'm using the STM32F423ZHT6 for a Smart Lock with 2 limit switches for lock/unlock. The problem is, the motor stays on all the time, so it’s using a lot of power. Any tips on (https://faisalmoversonline.pk/) how to reduce this? I want the motor to run only when needed.
    Andrew Neil
    Andrew NeilBest answer
    Duplicate: https://community.st.com/t5/stm32-mcus-motor-control/optimize-the-power/m-p/725536
    Andrew Neil
    Do you think you've presented details of the 'design' that are adequate to understand what you've built?
    If this is a class project, please work with your teacher or supervisor.
    Andrew Neil
    ^^^ Always this! ^^^
    @mabubilal is @Meenakshi your classmate, on the same project? If so, you should collaborate ...
