HALL sensor Pin out only 3.3v
- 4 replies
- 3683 views
Hello guys
I'm trying to do a profiler for Hall sensors.
But when I measured my Hall power pins they only provide 3.3V instead of 5.0V and my Hall sensor needs at least 4.5V, I tried to check my control board manual and found that my SW is in the right direction but it only provides 3.3V, I tried to turn it off with CUBE MX (Save power of non-active UCPD - deactive Dead Battery pull-up). deactive Dead Battery pull-up) but it doesn't turn it off. Please provide me some suggestions.
My control board with the power supply version is
G474RE+IPM20B
