ABlak.1
Generated .ioc file causes STM32CubeIde to throw an exception when it tries to open it
The attached ioc file causes STM32CubeIde to throw a nullptr excp.
It was generated by doing the following:
Open motor control wb 6.1.0
Follow the wizard to enter a v low inductance/resistance motor.
Select the B-G431B-ESC1 board
Generate the project
STM32CubeMX opens
"Generate Code"
Open STM32CubeIde
It opens and throws a NullPtrExcp
Please could someone at ST fix this defect?
ABlak.1
ABlak.1Best answer
I downloaded the installer again and reinstalled it - it now works.
ABlak.1
ABlak.1Author
I subsequently discovered this is the fault of the IDE and not specifically the ioc file. The IDE will not open any ioc file and in every case give a NullPtrExcp.
STM32CubeIDE
Version: 1.11.0
Build: 13638_20221122_1308 (UTC)
Windows 10.
ABlak.1
ABlak.1AuthorBest answer
