Schmesterle
Apr 3, 2025 8:25 AM UTC
External memory on stspin32g4 possible
Hello
Is it possible to connect an external memory IC to the stspin via qspi or spi interface and map the addresses into the addressable space of the cpu?
Andrew Neil
Andrew NeilBest answer
Apr 3, 2025 8:45 AM UTC
STM32G431VB is the chip on the stspin32g4 board!
https://www.st.com/en/motor-drivers/stspin32g4.html
Andrew Neil
Apr 3, 2025 8:35 AM UTC
Have you looked at the datasheet for the STM32G431VB ?
Schmesterle
Apr 3, 2025 8:39 AM UTC
Didn't look into other products, because we need the stspin with integrated drive stage.
Andrew Neil
Schmesterle
Apr 3, 2025 8:50 AM UTC
Ah, now I understand you. Thank you very much for this hint. I will take a look into the MCU!
