EVSPIN958-SingleMotor firmware
Hi, i'm using NUCLEO-F401RE product with EVSPIN958 expantion board connected to, for motor control.
I've connected this with STSPIN Studio 2.0, it's running correctly with EVSPIN958-SingleMotor firmware (i'm using DC brushed motor).
i'm just searching EVSPIN958-SingleMotor firmware code to use it as exemple.
I don't have found it on your site. Can you give me link to this information.
thanks.
Cristiana SCARAMEL
Hello @de82 and welcome to the ST Community.
In general, for the STSPIN Studio environment we do not provide the code to drive the boards.
I can suggest you develop the code according to your application. You can use STM32CubeMX to set a timer for the PWM signal and possibly a timer for the current limiter.
"If you feel a post has answered your question, please click ""Accept as Solution"""
