Mar 9, 2025 5:25 AM UTC
EVLSERVO1 Over Current Protection (OCP)
- 6 replies
- 1997 views
Hello everyone,
Based on the screenshots attached, I couldn't understand the formula obtained for the OCP feature of this inverter board.
3 phase currents are read through the shunt resistors, got offset, and amplified by the op-amp ICs. So far so good!
But PC1, PC2, and PC3 are tied together using 3 one kilo ohm resistors, then the common node is fed to the comparator pin of the MCU to do the OCP task.
I am wondering how the Equation 2 is obtained for implementing over current protection, and why it is like this.
Why is the G.Rs.Ioc term divided by 3?
If you could guide me, it'd be awesome, thanks.
