Ryada.1
Encoder alignment process?
Hi sir can any one explains encoder alignment process in st motor control workbench in st eval 3202 board ​
Laurent Ca...
Senior III
Dear @Ryada.1​
Sorry for the late answer.
Do you have still this problem to solve?
And just in case, if not, do not hesitate to share the final solution you found. Thanks by advance.
Best regards
Laurent Ca...
Laurent Ca...
Senior III
The question has been set only to the "STM32 Motor Control" topic (the question is only about the STM32 MC SDK).
Best regards
