Electronic Speed Control with STSPIN32G0A2
I am Designing a custom motor control board using the STSPIN32G0A2.
In the MC Workbench with the Board Designer I can select the function Electronic Speed Control an connect it with PA15.
When I create a new project the function is no longer available.
For me it seems like a bug that the controller is not capable for this function. But then inside the board designer it should not be allowed to select the function.
ST Eval Board with this controller do not support ESC function.
There was a similar question with a different controller, but there was no answer.
What is the reason for this behaviour?
Thank you very much.
