cuurent waveform
Hi, I have a bldc motor with encoder, the output current waveform is not sinusoidal. i have used motor profiler to measure rs=0.2mOhm and ls = 0.6mH. what should I do. I also cant tune the pid so that the rpm of motor will be constant under load.
