JCheg
connection problem in ST Motor Profiler
I am using a nucleo-f302r8 and x-nucleo-ihm07m1 in order to controll a BLDC motor. I have installed the (ST Motor control workbench). when I run the st motor profiler and try to connect, I see the following message:
"unable to identify the exact number of boards connected by means of ST-LINK"
I have installed and upgraded ST-LINK usb driver properly. I use windows 10.
I appreciate your help to solve this connection problem
Ahetz.1
did you solved your problem?
Laurent Ca...
Senior III
The question has been moved from the section "Motor Control Hardware" to the "STM32 Motor Control" section (the question is about the STM32 MC SDK).
Best regards
