GMA
GMABest answer
Hello @Danu_Park,
Using Motor Control Pilot tool, "Graph & Record" left button, and select ELectrical ANGLEs to display:
If you agree with the answer, please accept it by clicking on 'Best answer'.Best regards.GMA
GMA
Hello @Danu_Park,
Could you verify motor connect connection: U, V and W phases and Encoder signal?
Did you try using Sensor Less as Main speed sensing and Encoder as Auxiliary to check that both reported electrical angles are aligned?
Danu_Park
Danu_ParkAuthor
Complete
Danu
Danu_Park
Danu_ParkAuthor
Complete
Danu
GMA
Hello @Danu_Park,
Using Motor Control Pilot "Advanced Configuration", you can tune the position control PID regulator:
