Change  phase 120 degree to 90 degree in MotorControl Workbench 6.2.0?
Hi All ,
I need to change  phase 120 degree to 90 degree in MotorControl Workbench 6.2.0
Can change in file mc_math.c?
For use single phase motor 3 wire
Please help me for advice.
BR,
METHEE
    cedric H
    cedric HBest answer
    Hello @methee_c
    I am not an ACIM expert but your motor sounds weird to me.
    You mentioned single phase? three wires? and an angle of 90 degrees...
    Do you have any commercial reference of your motor I can look at?
    Cedric
    SRedd.5
    Senior III
    Do you use FOC (sensored / sensor less) , 6 step commutation? What you want to change in mc_math.c?
    methee_cAuthor
    Hi @SRedd.5
    I test run on ACIM open loop,I see  table and config in mc_math
    You can help me for Change  phase 120 degree to 90 degree in MotorControl Workbench 6.2.0?
    BR,
    METHEE
    cedric H
    cedric HBest answer
    Hello @methee_c
    Cedric
