mkk.1
Cant generate project
Hi, firstly I installed java 8 and I installed STM32Cubemx 5.6. after that I installed X-CUBE-MCSDK. But gave message in the setting of the project generation that "STM32CubeMX not found - ver. "5.2.0" or higher is required".
Laurent Ca...
Senior III
The question has been moved from the "Motor Control Hardware" section to the "STM32 Motor Control" section (the question is about the STM32 MC SDK).
Best regards
