LXU.1
Can the current controlled by the motor reach 40A? The current of the motor I see is very small and cannot meet the requirements. How can I make a 40A current motor and use it? (automatic translation)
Original title:
电机控制的电�?能到达40A嘛?我现在看到的电机的电�?很�?,�?能够满足�?求,我怎么能�?��?40A电�?的电机也能用呢?
Peter BENSCH
It may be a good idea to change the heading language to English. I've translated your question using a translation tool to increase the chances of getting you a reply from our experts and community members, since the majority interact in English.
Here is the translation of your question (headline) using Google translate:
Good luck!
/Peter
Laurent Ca...
Senior III
Dear @LXU.1​
I changed your title "电机控制的电�?能到达40A嘛?我现在看到的电机的电�?很�?,�?能够满足�?求,我怎么能�?��?40A电�?的电机也能用呢"
by the one prposed by @Peter BENSCH​ .
Could you either confirm it is OK or edit your title if not?
Thanks by advance.
Best regards
