SRedd.5
Senior III
I don't think it is build error, i think the motor is running but not able to reach the maximum RPM, is my understanding correct?
Hello @vishu
Indeed @SRedd.5 , the error is popped up due to the maximum speed measured. You cannot reach 1998 rpm with this configuration.
vishuAuthor
How to overcome from this error? Is there any solution??
