Best method to measure temperature of STSPIN32G4
I made some temperature measures on STSPIN32G4 using a thermal camera.
I saw that the central part 3x3mm of the STSPIN reaches about 70°C, while the sorrounding part does not go beyond 50°C.
My question is the following: if I use the internal temperature sensor I will read the temperature of the central part or the sorrounding part?
Thank you
Federico
    Cristiana SCARAMEL
    Hello @FedericoHW and welcome to the ST Community.
    I confirm that the internal temperature sensor reports the temperature of the device central part.
    "If you feel a post has answered your question, please click ""Accept as Solution"""
    Cristiana SCARAMEL
