LHerm.1
Are there librairies to control the Powerstep01 ?
Hello everyone, I'm using the evaluation board of the motor driver POWERSTEP01 with a nucleo board NUCLEO-F401-RE. As the powerstep01 works by writing in regsitres via SPI, I would like to know if there are one or more libraries that allow the functions to be used directly in my program ?
Thank for your help
Peter BENSCH
Peter BENSCHBest answer
Did you already check the software package X-CUBE-SPN3, which also contains a driver in Drivers\BSP\Components\powerSTEP01?
/Peter
Peter BENSCH
/Peter
Peter BENSCH
Good luck!
/Peter
LHerm.1
LHerm.1Author
Thank for your help !
Peter BENSCH
You're welcome, the community will always be happy to support you.
