FFedo.1
Are nucleo L476RG and ihm16m1 expansion board compatible?
Hi everyone,
I try to get my motor control setup working:
Hardware: Nucleo  L476RG with ihm16m1 expansion board, motor Gart ML5008 330KV, 24V power supply
I am trying to get my BLDC motor to spin by using motor control FOC library.
I generated example project with Motor control workbench and managed to run it but the motor does not spin.
My questions:
Is this hardware even compatible?
Are there any good tutorials or example projects to begin with?
Thanks in advance.
Laurent Ca...
Senior III
Dear @FFedo.1​
Sorry for the late answer.
Do you have still this problem to solve?
And just in case, if not, do not hesitate to share the final solution you found. Thanks by advance.
Best regards
Hi
Can you please answer his question. Are these boards compatible ?
Younes
