hritter
X-CUBE-GNSS1
I have a project that will be using the LIV4F chip. I downloaded and installed X-CUBE-GNSS1 but its description says it is for the LIV3F. Is it compatible with and will it function with the LIV4F chip? I will be using it on the STM32G474CEU6.
Thanks!
hritter
hritterBest answer
This post can be ignored. It seems I did not have the window open wide enough. Sure enogh the description states that it is for the LIV4F also.
hritter
hritterAuthorBest answer
