X-CUBE-AUDIO: USB audio high speed not work with iOS
  • August 6, 2025
  • 5 replies
  • 650 views
I use stm32h7r3 to develop USB audio recording function. My device can work successful in Ubuntu/Android/Windows, but failed in iOS. I had tried many iOS version, but still can't work.  The below is my device USB parameters:
2 channels L/R
32 bit  data length
48KHz sample rate
High speed
UAC1.0
my reference code(stm32F769I) from https://www.st.com/en/embedded-software/x-cube-audio.html
Could someone give me some advice?
Best answer by FBL
Hi @Tony2Simmy
X-CUBE-AUDIO-KIT supports STM32H7RS products.
FBLBest answer
Hi @Tony2Simmy
I find out UAC2.0 and tinyusb library in X-CUBE-AUDIO-KIT.
Do ST have plan to update UAC1.0 to UAC2.0 in X-CUBE-AUDIO?
Senior
October 16, 2025
Were you able to get anywhere?
HS is not supported in UAC1.0, so you're on the right track to use UAC2.0.
AScha.3
Did you try with a standard setting?
Like: 48k, 16bit, stereo/2ch ?
When I change high speed to full speed, iOS can detect my USB device.
It seems that iOS can't support HS in UAC1.0.
