KChan.15
Aug 2, 2021 10:19 AM UTC
Windows 10 with only USB3.0 ports, didn't detect the STM32 device when I use Dfuse. Tried the STM Bootloader but no luck, the notes said Win10 didn't need the STM Bootloader and it's not supported. Please help!
Aug 2, 2021 1:32 PM UTC
If nothing shows up in the device manager, the chip is probably not in bootloader mode. If you're jumping to the bootloader, ensure you haven't disabled interrupts.
DfuSe is NRND status (deprecated). You might have more luck with STM32CubeProgrammer. Choose the "USB" protocol to connect.
What notes?
Pavel A.
Aug 3, 2021 8:14 PM UTC
Does any other PC detect it? If so, try to connect this device thru a USB 2.0 hub.
