parth kothiya
Mar 10, 2022 3:27 AM UTC
Which driver having lower execution time HAL or LL?
Which driver is faster from HAL or LL so cpu can perform other important tasks.
For example to read & write gpio
​Using HAL driver,
Using LL driver,
Using direct access MCU resistor.​
TDKBest answer
Mar 10, 2022 3:39 AM UTC
Direct register access will always be the fastest.
TDKBest answer
parth kothiya
Mar 10, 2022 4:06 AM UTC
Can we use both drivers in same application code writing using HAL + LL + Direct access MCU resistor all of this?​
Mar 10, 2022 4:31 AM UTC
Yes. A little silly to do so, however. Need to ensure the HAL state machine doesn’t get disturbed but your other code.
S.Ma
Principal
Mar 10, 2022 3:56 AM UTC
You just described the list in increasing achievable performance level. Apart from this, maybe not all the code requires to be best performance...
