AGupt.17
Mar 14, 2022 7:25 PM UTC
Where to download STM32Cube middleware for audio PDM to PCM conversion, from. The pare has a download option , and the option is not active
kindly help me in downloading the STM32 PDM to PCM convertor driver for F4 series microcontroller​
Walid ZRELLI
Mar 18, 2022 1:40 PM UTC
Hello @AGupt.17​
You can refer to the following example which uses  PDM to PCM conversion in the waverecorder part:
  • Projects\STM32F411E-Discovery\Applications\Audio\Audio_playback_and_record
The pdm2pcm lib is provided under this path: Middlewares\ST\STM32_Audio\Addons\PDM
I hope this helps.
BeST Regards,
Walid
waclawek.jan
Oct 29, 2022 8:31 AM UTC
Hi Walid,
I understand that this is a moving target. Sadly.
https://github.com/STMicroelectronics/STM32CubeF4/tree/master/Middlewares/ST/STM32_Audio/Addons/PDM currently is empty, contains only readme.txt which tells us to go to https://www.st.com/en/licensed-software/audiopdm-mw.html?softwareProduct=AudioPDM-MW&softwareVersion=3.2.0 and that in turn just throws a generic 404.
Shouldn't there be a web folder for the PDM-PCM library, to which UM2372 belongs?
@Walid ZRELLI​
