Riccardo Franceschetto
Mar 31, 2023 12:55 PM UTC
What woul be the best way to read ADC in an RTOS?
I'd like to get ADC readings, implemented with DMA while running in an RTOS.
The problem is that the ADC with DMA interrupts the RTOS... don't know what could be the cause maybe interrupts conflicting?
Mar 31, 2023 1:50 PM UTC
Hello @Riccardo Franceschetto​
I think you should configure the DMA controller to trigger an interrupt only when a buffer is completely filled! have you tried that?
Apr 3, 2023 6:33 AM UTC
Hello Sarra,
I created a one element array, so the HAL_ADC_ConvCpltCallback get called every sample the adc feeds to the DMA.
Theoretically this should be a good implementation, but practically i think i'm stopping the GUI too frequently.
