using emWin with LCD with three controllers
Posted on December 28, 2014 at 11:08
Hi everyone
I'm trying to display on LM19264k LCD which is controlled by 3 controllers of type S6B0108 I'm usingthree instances of GUIDRV_SPage display driver of emWin and a GUIDRV_DIST driver of emWin. I'm able to display on the LCD, the problem is that when I tried to display my name ''Salahuddin'' on the LCD usingGUI_DispStringAt(''Salahuddin Ashraf'', 0, 0); my name was displayed 4 timesvertically and 3 timeshorizontally .. and it was overlapped like this ''Ashrafdin''
here's my code
// Physical display size (128 x 64)
#define XSIZE_PHYS 192
#define YSIZE_PHYS 64
// color conversion
#define COLOR_CONVERSION GUICC_1
// Display driver
#define DISPLAY_DRIVER GUIDRV_SPAGE_1C0
// Buffers / VScreens
#define NUM_BUFFERS 1 // Number of multiple buffers to be used
#define NUM_VSCREENS 1 // Number of virtual screens to be used
* Public code
* LCD_X_Config
* Purpose:
* Called during the initialization process in order to set up the
* display driver configuration.
void LCD_X_Config(void) {
CONFIG_SPAGE Config = {0};
GUI_DEVICE *pDevice, *pDevice0, *pDevice1, *pDevice2;
GUI_PORT_API PortAPI = {0};
GUI_RECT Rect0, Rect1, Rect2;
// At first initialize use of multiple buffers on demand
#if (NUM_BUFFERS > 1)
GUI_MULTIBUF_Config(NUM_BUFFERS);
#endif
// Set display driver and color conversion for 1st layer
// On success the function returns a pointer to the created device object,
// otherwise it returns NULL
pDevice = GUI_DEVICE_CreateAndLink(GUIDRV_DIST, COLOR_CONVERSION, 0, 0);
// Display driver configuration, required for Lin-driver
if (LCD_GetSwapXY()) {
LCD_SetSizeEx (0, YSIZE_PHYS, XSIZE_PHYS);
LCD_SetVSizeEx(0, YSIZE_PHYS * NUM_VSCREENS, XSIZE_PHYS);
} else {
LCD_SetSizeEx (0, XSIZE_PHYS, YSIZE_PHYS);
LCD_SetVSizeEx(0, XSIZE_PHYS, YSIZE_PHYS * NUM_VSCREENS);
LCD_SetVRAMAddrEx(0, (void *)VRAM_ADDR);
// Create first display driver
pDevice0 = GUI_DEVICE_Create(DISPLAY_DRIVER, COLOR_CONVERSION, 0, -1);
// Configuration of first driver
// Driver configuration
Config.FirstSEG = 0;
Config.FirstCOM = 0;
GUIDRV_SPage_Config(pDevice0, &Config);
// Configure hardware routines
PortAPI.pfWrite8_A0 = vWriteCommand;
PortAPI.pfWrite8_A1 = vWriteData;
PortAPI.pfWriteM8_A1 = vWriteDataM;
PortAPI.pfRead8_A1 = u8ReadData;
PortAPI.pfRead8_A0 = u8ReadStatus;
GUIDRV_SPage_SetBus8(pDevice0, &PortAPI);
// Controller configuration
GUIDRV_SPage_Set1510(pDevice0);
// Create second display driver
pDevice1 = GUI_DEVICE_Create(DISPLAY_DRIVER, COLOR_CONVERSION, 0, -1);
// Configuration of second driver
GUIDRV_SPage_Config(pDevice1, &Config);
GUIDRV_SPage_SetBus8(pDevice1, &PortAPI);
GUIDRV_SPage_Set1510(pDevice1);
// Create third display driver
pDevice2 = GUI_DEVICE_Create(DISPLAY_DRIVER, COLOR_CONVERSION, 0, -1);
GUIDRV_SPage_Config(pDevice2, &Config);
GUIDRV_SPage_SetBus8(pDevice2, &PortAPI);
GUIDRV_SPage_Set1510(pDevice2);
// Add display drivers to distribution driver
Rect0.x0 = 0;
Rect0.y0 = 0;
Rect0.x1 = 63;
Rect0.y1 = 63;
GUIDRV_Dist_AddDriver(pDevice, pDevice0, &Rect0);
Rect1.x0 = 64;
Rect1.y0 = 0;
Rect1.x1 = 127;
Rect1.y1 = 63;
GUIDRV_Dist_AddDriver(pDevice, pDevice1, &Rect1);
Rect2.x0 = 128;
Rect2.y0 = 0;
Rect2.x1 = 191;
Rect2.y1 = 63;
GUIDRV_Dist_AddDriver(pDevice, pDevice2, &Rect2);
// Set user palette data (only required if no fixed palette is used)
#if defined(PALETTE)
LCD_SetLUTEx(0, PALETTE);
#endif
Can anyone tell me how to fix this and how to write on the LCD like just one LCD not three similar LCDs ?
Thanks in advance
#emwin #freertos #stm32f4
