Sep 4, 2022 9:33 AM UTC
Using DAC1_2 with SDRAM and HS USB PHY
Is this possible - even in a hacky way.
the OPAMP2_VOUT (PE7 follower) output clashes with FMC_D4
the DAC1_OUT2 pin (PA5) clashes with USB HS ULPI CK
So is any configuration possible where DAC1_2, USB HS and SDRAM can work together?
