Senior
USBX Ux Audio - Recording - github not found
Hello, I've been following closely with the github while I work on the recording portion myself, and I saw that x-cube-azrtos-h7 was updated today.
I immediately looked for the recording project, and couldn't find it. Even this page shows up Error 404: https://github.com/STMicroelectronics/x-cube-azrtos-h7/tree/main/Projects/STM32H743I-EVAL/Applications/USBX/Ux_Device_Audio20_Recording
Do I not have access to it?
FBLBest answer
Hi @audio
Some projects are unavailable in this repository. Some middleware libraries along with the projects (demos, applications, and examples) using them, are not available.
List of unavailable projects:
  • ./Projects/STM32H743I-EVAL/Applications/USBX/Ux_Device_Audio2.0_PlayBack
  • ./Projects/STM32H743I-EVAL/Applications/USBX/Ux_Device_Audio20_Recording
Instead, you can check st website.
Hi @audio
Thank you for reporting this issue.
I will check internally and get back to you ASAP.
FBLBest answer
Hi @audio
