matt-crc
Senior III
Apr 1, 2025 6:36 AM UTC
UsbX memory split memory pools
I was looking at the UsbX middleware source code and noticed that the memory pools are split in 2.
a) non-cached memory pool
b) cached memory pool
The STM implementation doesn't seem to use this code and just places everything into the non-cached memory pool.
So my questions are:
1- has anyone used the split memory pools, and does it actually work? -OR- it doesn't work and that's why it was disabled by ST.
2- if it is enabled, how much of a performance boost will it provide? and is it worth the time and effort to split the pools?
thanks, Matt
FBLBest answer
May 5, 2025 2:22 PM UTC
Hi @matt-crc
Only non-cached memory to be used to ensure cache coherency on STM32 products with Data cache support.
FBLBest answer
Hi @matt-crc
