ABasi.2
Senior
Mar 11, 2025 1:18 PM UTC
USBX endpoint address error , UX_MAX_DEVICE_ENDPOINTS
Hi!
with cube IDE i'm trying to develop a USB device with 3 classes using  a STM32H523 with USBX and threadX.
If i select USB HID,USB MSC and USB ACM (virtual com port) the code is succesfully generated but if i close and reopen the .ioc GUI i have this message error:
the value of UX_MAX_DEVICE_ENDPOINTS can't be less then number of endpoints used.(used endpoints: 7). it will be set to 6.
what does it mean? is not possible to have 3 classes? or i have to change something in the endpoints and it can be done?
there is an example like this? or a guide to understande the endspoint manage
thank you
Mohamed_AYEDBest answer
Explorer
Mar 12, 2025 11:56 AM UTC
Hi @ABasi.2
in stm32h5 the max endpoint is 8
In your project you are using
  • ep 0 for controll (mondatory)
  • ep 1 for hid class
  • ep 1 for storage in
  • ep 2 for storage out
  • ep 3 for cdc acm ctl
  • ep 4 for cdc acm in
  • ep 5 for cdc acm out
if you define this endpoints config the problem will dispparate in Mx
ensure that UX_DEVICE_BIDIRECTIONAL_ENDPOINT_SUPPORT is enbled
  • ep 0 for controll
  • ep 1 for hid
  • ep 2 for storage in
  • ep 3 for ctl
  • ep 4 for cdc acm out
  • total is 5 endpoints < max enpoints availble in this product
Mar 11, 2025 2:05 PM UTC
Hi @ABasi.2
Would you attach ioc file to reproduce? Make sure to use latest version.
ABasi.2
ABasi.2Author
Senior
Mar 11, 2025 3:04 PM UTC
Thankyou!
sure i can attach the ioc file
my cube ide is 1.17.0
Explorer
Hi @ABasi.2
  • ep 0 for controll
  • ep 1 for hid
  • ep 3 for ctl
ABasi.2
ABasi.2Author
Senior
Mar 13, 2025 7:14 AM UTC
Hello Mohamed
thank you!
threre is a manual / video guide ecc about this topic that you know? i 'm new in USB and a want to learn
Is it possible to use the same end point for 2 different classes?
i saw a video from ST : https://www.youtube.com/watch?v=wCRIpp-OHY4&t=167s
where it seems possible if you respect the in and out configuration of endpint
thank you
