HHans.1
July 17, 2020
USB stops receiving and/or transmitting data after short time using Async endpoint
  • July 17, 2020
  • 0 replies
  • 519 views
I have a problem using ISOC ASYNC USB endpoint.
I am using Audio Class 2.0
3 endpoints, (To Host, Feedback to host, from host)
If I only enable receiving data from host then I will receive the data.
If I only enable transmitting data to host then I will transmit the data.
If I enable both transmit and receiving then transmit will always transmit data, but receive will only receive x amount and then stop. It does not trigger ISOINComplete or any other known fault.
Has anyone had similar problems?
