USB PD SINK - automatic APDO/PDO
Hello everybody
I'm working with USB PD sink on my own board with STM32G071KBT6 microcontroller ad development software: STM32CubeIDE 2.1.1 and STMCubeMX 6.17 (freeRTOS, without TCPP, with my own protection of VBUS and CC lines).
I want to set sink to APDO 24 V (if the charger accept it) or otherwise 20 V PDO.
Unfortunatelly if the charger, which I use, not accept APDO 24 V, it send hardreset and cut off the Vbus, so I can't use the flag to inform about the status (APDO or PDO).
Is there any way to read the PDOs from the source and on based on this choose APDO or PDO?
I have no structure DPM_Ports, and
USBPD_DPM_GetDataInfo(PortNum, USBPD_CORE_DATATYPE_RCV_SRC_PDO, buffer, &size);
returns size = 0;
Best regards
Jaroslaw_TBest answer
OK, now it is correct:
void USBPD_DPM_SetDataInfo(uint8_t PortNum, USBPD_CORE_DataInfoType_TypeDef DataId, uint8_t *Ptr, uint32_t Size)
/* USER CODE BEGIN USBPD_DPM_SetDataInfo */
 /* Check type of information targeted by request */
 switch(DataId)
 //case USBPD_CORE_DATATYPE_RDO_POSITION: /*!< Reset the PDO position selected by the sink only */
 // break;
 case USBPD_CORE_DATATYPE_RCV_SRC_PDO: /*!< Storage of Received Source PDO values */
	 DPM_USER_DEBUG_TRACE(PortNum, "Received: %lu bytes", Size);
	 uint8_t PDO_Number = Size/4;
	 if(Size==0U || Size%4U != 0U)
		 DPM_USER_DEBUG_TRACE(PortNum, "Invalid size - run fixed PDO");
		 If_APDO = 0U;
		 break;
	 for(uint8_t a=0; a<PDO_Number; a++)
		 PDO_1=0;
		 PDO_2=0;
		 PDO_3=0;
		 PDO_4=0;
		 PDO=0;
		 PDO_1=(uint32_t)Ptr[a*4U+0U]<<0;
		 PDO_2=(uint32_t)Ptr[a*4U+1U]<<8;
		 PDO_3=(uint32_t)Ptr[a*4U+2U]<<16;
		 PDO_4=(uint32_t)Ptr[a*4U+3U]<<24;
		 PDO=PDO_1|PDO_2|PDO_3|PDO_4;
		 DPM_USER_DEBUG_TRACE(PortNum, "PDO[%u] = 0x%08lX", a, PDO); //for information
		 if((PDO&0b11000000000000000000000000000000UL)==0b11000000000000000000000000000000UL) //if APDO
			 uint32_t Max_Voltage_100mV=(PDO>>17);
			 Max_Voltage_100mV = Max_Voltage_100mV&0b00000000000000000000000111111111;
			 DPM_USER_DEBUG_TRACE(PortNum, "APDO [%u] - max voltage: %lu * 100mV = %lu mV", a, Max_Voltage_100mV, (Max_Voltage_100mV*100));
			 if(Max_Voltage_100mV>=210U) //if APDO>=21V
				 If_APDO = 1U;
				 break;
 break;
Trace:
CAD	2	1	USBPD_CAD_STATE_DETACHED	581
CAD	4	1	USBPD_CAD_STATE_ATTACHED_WAIT	582
CAD	123	1	USBPD_CAD_STATE_ATTACHED	583
NOTIF	123	1	USBSTACK_START	584
DEBUG	123	1	ADVICE: USBPD_DPM_Notification:104	585
EVENT	123	1	EVENT_ATTACHED	586
DEBUG	123	1	ADVICE: update USBPD_DPM_UserCableDetection	587
DEBUG	123	1	ADVICE: USBPD_DPM_Notification:104	588
DEBUG	123	1	ADVICE: update USBPD_DPM_SetDataInfo:2	589
DEBUG	124	1	ADVICE: update USBPD_DPM_SetDataInfo:6	590
PE	124	1	PE_SNK_STARTUP	591
PE	124	1	PE_SNK_WAIT_FOR_CAPABILITIES	592
IN	125	1	SOP	 PD3	s:026	 H:0x61A1 	(id:0, DR:DFP, PR:SRC) 	SRC_CAPABILITIES	DATA: 2C9101082CD102002CC103002CB10400454106004121A4C9
Option: 	EPW
 [1] Fixed : 5V - 3A
 [2] Fixed : 9V - 3A
 [3] Fixed : 12V - 3A
 [4] Fixed : 15V - 3A
 [5] Fixed : 20V - 3.25A
 [6] Programmable : [3.3V - 21V] - 3.25A
	593
OUT	125	1	SOP	s:002	 H:0x0041 (id:0, DR:UFP, PR:SNK) 	GOODCRC	594
DEBUG	126	1	Received: 24 bytes	595
DEBUG	126	1	PDO[0] = 0x0801912C	596
DEBUG	126	1	PDO[1] = 0x0002D12C	597
DEBUG	126	1	PDO[2] = 0x0003C12C	598
DEBUG	126	1	PDO[3] = 0x0004B12C	599
DEBUG	126	1	PDO[4] = 0x00064145	600
DEBUG	126	1	PDO[5] = 0xC9A42141	601
DEBUG	127	1	APDO [5] - max voltage: 210 * 100mV = 21000 mV	602
PE	127	1	PE_SNK_EVALUATE_CAPABILITY	603
PE	128	1	PE_SNK_SEND_REQUEST	604
OUT	128	1	SOP	 PD3	REQUEST	s:006	 H:0x1082 	(id:0, DR:UFP, PR:SNK) DATA: 3C340863
ObjectPosition:6
GiveBack:0
CapabilityMismatch:0
USBCommunicationCapable:1
NoUSBSuspend:1
UnchunkedExtendedMessagesSupported:0
Operating Current:3000mA
Operating Voltage:21000mV	605
IN	129	1	SOP	s:002	 H:0x0121 (id:0, DR:DFP, PR:SRC) 	GOODCRC	606
PE	129	1	PE_SNK_SELECT_CAPABILITY	607
IN	133	1	SOP	 PD3	ACCEPT	s:002	 H:0x03A3 (id:1, DR:DFP, PR:SRC) 	608
OUT	133	1	SOP	s:002	 H:0x0241 (id:1, DR:UFP, PR:SNK) 	GOODCRC	609
NOTIF	134	1	POWER_STATE_CHANGE	610
DEBUG	134	1	ADVICE: USBPD_DPM_Notification:90	611
NOTIF	134	1	REQUEST_ACCEPTED	612
DEBUG	134	1	ADVICE: USBPD_DPM_Notification:1	613
PE	134	1	PE_SNK_TRANSITION_SNK	614
IN	368	1	SOP	 PD3	PS_RDY	s:002	 H:0x05A6 (id:2, DR:DFP, PR:SRC) 	615
OUT	368	1	SOP	s:002	 H:0x0441 (id:2, DR:UFP, PR:SNK) 	GOODCRC	616
NOTIF	369	1	POWER_STATE_CHANGE	617
DEBUG	369	1	ADVICE: USBPD_DPM_Notification:90	618
NOTIF	369	1	POWER_EXPLICIT_CONTRACT	619
DEBUG	369	1	ADVICE: USBPD_DPM_Notification:16	620
PE	369	1	PE_STATE_READY	621
NOTIF	369	1	STATE_SNK_READY	622
DEBUG	369	1	ADVICE: USBPD_DPM_Notification:32	623
PE	369	1	PE_STATE_READY_WAIT	624
OK it is possible now to switch between APDO and (if APDO is not possible) PDO.
Code:
 switch(DataId)
 // break;
		 If_APDO = 0U;
		 break;
		 PDO_1=0;
		 PDO_2=0;
		 PDO_3=0;
		 PDO_4=0;
		 PDO=0;
		 if((PDO&0b11000000000000000000000000000000UL)==0b11000000000000000000000000000000UL) //if APDO exist
			 uint32_t Max_Voltage_20mV=(PDO>>9);
			 Max_Voltage_20mV = Max_Voltage_20mV&0b00000000000000000000011111111111; //masking
			 DPM_USER_DEBUG_TRACE(PortNum, "APDO [%u] - max voltage: %lu * 20mV = %lu mV", a, Max_Voltage_20mV, (Max_Voltage_20mV*20));
			 if(Max_Voltage_20mV>=1050U) //if APDO>=21V
				 If_APDO = 1U;
				 break;
 break;
But the returned voltage value of APDO is not correct. Should be 1050 (21V) but is 528.
Trace:
CAD	2	1	USBPD_CAD_STATE_DETACHED	446
CAD	4	1	USBPD_CAD_STATE_ATTACHED_WAIT	447
CAD	123	1	USBPD_CAD_STATE_ATTACHED	448
NOTIF	123	1	USBSTACK_START	449
DEBUG	123	1	ADVICE: USBPD_DPM_Notification:104	450
EVENT	123	1	EVENT_ATTACHED	451
DEBUG	123	1	ADVICE: update USBPD_DPM_UserCableDetection	452
DEBUG	123	1	ADVICE: USBPD_DPM_Notification:104	453
DEBUG	123	1	ADVICE: update USBPD_DPM_SetDataInfo:2	454
DEBUG	124	1	ADVICE: update USBPD_DPM_SetDataInfo:6	455
PE	124	1	PE_SNK_STARTUP	456
PE	124	1	PE_SNK_WAIT_FOR_CAPABILITIES	457
Option: 	EPW
 [1] Fixed : 5V - 3A
 [2] Fixed : 9V - 3A
	458
OUT	125	1	SOP	s:002	 H:0x0041 (id:0, DR:UFP, PR:SNK) 	GOODCRC	459
DEBUG	126	1	Received: 24 bytes	460
DEBUG	126	1	PDO[0] = 0x0801912C	461
DEBUG	126	1	PDO[1] = 0x0002D12C	462
DEBUG	126	1	PDO[2] = 0x0003C12C	463
DEBUG	126	1	PDO[3] = 0x0004B12C	464
DEBUG	126	1	PDO[4] = 0x00064145	465
DEBUG	127	1	PDO[5] = 0xC9A42141	466
DEBUG	127	1	APDO [5] - max voltage: 528 * 20mV = 10560 mV	467
PE	127	1	PE_SNK_EVALUATE_CAPABILITY	468
PE	128	1	PE_SNK_SEND_REQUEST	469
OUT	128	1	SOP	 PD3	REQUEST	s:006	 H:0x1082 	(id:0, DR:UFP, PR:SNK) DATA: 2CB10453
ObjectPosition:5
GiveBack:0
NoUSBSuspend:1
MaximumOperatingCurrent:3000mA
OperatingCurrent:3000mA	470
IN	129	1	SOP	s:002	 H:0x0121 (id:0, DR:DFP, PR:SRC) 	GOODCRC	471
PE	129	1	PE_SNK_SELECT_CAPABILITY	472
IN	133	1	SOP	 PD3	ACCEPT	s:002	 H:0x03A3 (id:1, DR:DFP, PR:SRC) 	473
OUT	133	1	SOP	s:002	 H:0x0241 (id:1, DR:UFP, PR:SNK) 	GOODCRC	474
NOTIF	134	1	POWER_STATE_CHANGE	475
DEBUG	134	1	ADVICE: USBPD_DPM_Notification:90	476
NOTIF	134	1	REQUEST_ACCEPTED	477
DEBUG	134	1	ADVICE: USBPD_DPM_Notification:1	478
PE	134	1	PE_SNK_TRANSITION_SNK	479
IN	382	1	SOP	 PD3	PS_RDY	s:002	 H:0x05A6 (id:2, DR:DFP, PR:SRC) 	480
OUT	382	1	SOP	s:002	 H:0x0441 (id:2, DR:UFP, PR:SNK) 	GOODCRC	481
NOTIF	383	1	POWER_STATE_CHANGE	482
DEBUG	383	1	ADVICE: USBPD_DPM_Notification:90	483
NOTIF	383	1	POWER_EXPLICIT_CONTRACT	484
DEBUG	383	1	ADVICE: USBPD_DPM_Notification:16	485
PE	383	1	PE_STATE_READY	486
NOTIF	383	1	STATE_SNK_READY	487
DEBUG	383	1	ADVICE: USBPD_DPM_Notification:32	488
PE	383	1	PE_STATE_READY_WAIT	489
What is wrong?
Jaroslaw_TAuthorBest answer
 switch(DataId)
 // break;
		 If_APDO = 0U;
		 break;
		 PDO_1=0;
		 PDO_2=0;
		 PDO_3=0;
		 PDO_4=0;
		 PDO=0;
				 If_APDO = 1U;
				 break;
 break;
Trace:
Option: 	EPW
 [1] Fixed : 5V - 3A
 [2] Fixed : 9V - 3A
	593
ObjectPosition:6
GiveBack:0
NoUSBSuspend:1
