Oct 15, 2025 10:11 AM UTC
USB PD AVS support in X-CUBE-TCPP
I don't seam to see anything related to the implementation of the USB PD AVS system to allow a sink to request voltages of up to 48V. Am I miss-reading the X-CUBE-TCPP code? If it is missing, is there a plan to implement it?
Thanks a lot
Have a nice day
FBLBest answer
Oct 15, 2025 2:07 PM UTC
Hi @clement_roblot
AFAIK, you can extend the USB PD stack to parse and handle APDOs (Augmented PDOs) for AVS. Also, X-CUBE-TCPP package already support EPR mode. No hardware platforms for EPR (up to 240W) are provided yet.
FBLBest answer
Hi @clement_roblot
Oct 16, 2025 1:11 AM UTC
Oki doki, at least I will not be re-inventing the wheel if I implement that myself. Thanks a lot @FBL
