Nbaşa.1
USB HOST and DEVICE in same time
I want to use USB DEVICE and HOST mode in same code. Firstly, I added manuel libraries for host and device configuration. I can do Transiton of host to device or device to host with using init and deinit function of usb. After a while , this process doesn't work. Can anyone who has dealt with this issue help?
Walid ZRELLI
May 23, 2022
Hello @Nuri başar​
Unfortunately, we do not provide an example that uses the USB device and host in the same code.
Otherwise, it is probably possible by using the deinit and init usb functions.
BeST Regards,
Walid
