SVill.4
Feb 2, 2022 12:04 PM UTC
USB Composite Device
Good morning,
I need to create an USB Interface that supports two functions: Mass Storage + Virtual COM. Maybe someone has already implemented a similar solution or ST has created an example. I'm looking for an example, but i have not found anything up to now.
Thanks a lot.
Walid ZRELLI
Feb 8, 2022 9:31 AM UTC
Hello @SVill.4​ ,
You can refer to the following examples provided by our F7 software package which uses a multi-core feature:
  • Path: Projects\STM32746G-Discovery\Applications\USB_Device\DualCore_Standalone : Mass Storage (MSC) and Human Interface (HID)
  • Path: Projects\STM32756G_EVAL\Applications\USB_Device\DualCore_Standalone: Device Communication Class (CDC) and Human Interface (HID)
I hope this helps.
BeST Regards,
Walid
SVill.4
SVill.4Author
Feb 12, 2022 10:40 AM UTC
Hi @Walid ZRELLI​
Thank for your answer.
I need the low level driver for creating a composite USB device on same USB. This example uses USB FS and USB HS and pratically has two USB cable connected to MCU. I need two USB peripherals on same USB, like ST-LINK V3 on STM32H750-DK board, where there are USB CDC + USB MSC on same cable USB.
Best regards.
Piranha
Principal III
Feb 12, 2022 1:44 PM UTC
Don't waste your time with broken bloatware and take a look on sanely designed USB stack:
https://github.com/hathach/tinyusb/tree/master/examples/device/cdc_msc
