B??el
USB CDC to DAC
  • May 17, 2019
  • 0 replies
  • 514 views
Hi, I am succesfully sending the data through libusb to the changed CDC example. But i need to use the CDC_Receive_FS function to send the data from USB buffer to DAC with DMA. So USB transfer speed is faster than the speed Timer triggers the DAC-DMA event. So how do you think i can synchronise those two speeds? thanks
