MK..1
Aug 1, 2024 8:18 PM UTC
USB CDC and FreeRTOS
Hi
in different posts in forum I read ST's USB library is not thread safe. There are no examples with USB CDC and FreeRTOS.
Is that true?
Thx
FBLBest answer
Aug 5, 2024 8:51 AM UTC
Hi @MK..1
ST USB middleware is not explicitly using malloc() and free(), but it is crucial to configure it to use static memory allocation to ensure thread safety.
 * @brief Static single allocation.
 * @param size: Size of allocated memory
 * @retval None
void *USBD_static_malloc(uint32_t size)
 static uint32_t mem[(sizeof(USBD_CDC_HandleTypeDef)/4)+1];/* On 32-bit boundary */
 return mem;
 * @brief Dummy memory free
 * @param p: Pointer to allocated memory address
 * @retval None
void USBD_static_free(void *p)
Pavel A.
Aug 1, 2024 9:29 PM UTC
Yes. If you don't know why your software works, you have a potential risk.
Aug 2, 2024 9:18 AM UTC
Hi @MK..1
Usage of malloc(), free(), or any other function implicitly calling these functions is not safe in multi-threaded systems even in bare metal or RTOS systems. AN5731 provides some guidelines for ensuring thread safety.
MK..1
MK..1Author
Aug 2, 2024 10:21 AM UTC
Hi @FBL
how does AN5731 relate to ST USB library as it is not using malloc()?
I didn't find any malloc or free in the ST USB library!
Is there a specific reason why there is no CDC and FreeRTOS example project?
FBLBest answer
Hi @MK..1
 * @retval None
 return mem;
 * @retval None
