zhuij.1
May 19, 2021 9:44 AM UTC
Under the fixed 10Mbps mode of stm32f407 Ethernet, the current will be cut off for several minutes?
Under the fixed 10Mbps mode of stm32f407 Ethernet(inner MAC+external PHY), the net flow will be cut off for several minutes,but under fixed 100M or ETH_AUTONEGOTIATION_ENABLE ,the net flow is normal,is 10Mbps unavailable?
Piranha
Principal III
May 19, 2021 11:36 AM UTC
Check the values of ***_PHY_ADDRESS, PHY_SR, PHY_SPEED_STATUS, PHY_DUPLEX_STATUS defines.
