uart data mismatch
I am using stm32f407 and stm32wb series for sending the data usimg uart.
first i send th data using the stm32wb uart to the stm32f407 uart the data is correctly sent.
After receiving the data i will return the data back to the stm32wb from the stm32f407 but this time the data is corrupted.
I am using the hal_uart_receiveto_idle and hal_uart_transmit_it to send and receive the data.
I will share the code please review and tell me if i need to make any changes.
Hello @TejasK
Did you connect the GND between the two board?
In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question. Saket_Om
TejasKAuthor
Yes @Saket_Om  i have checked the connections one more time gnd is connected between the 2 boards. then what may be the other issue.
Andrew Neil
You haven't told us what board(s) you are using.
Please see: How to write your question to maximize your chances to find a solution
How, exactly, is it "corrupted" ?
Have you used an oscilloscope and/or logic analyser to see what's happening on the wires?
Have you tested & verified the stm32wb and stm32f407 separately?
Tips on debugging serial comms.
> HAL_UART_MspDeInit(&huart1);
> HAL_UART_MspInit(&huart1);
Don't call these while a transfer is in progress.
TejasKAuthor
I have removed these in the code.
Andrew Neil
And what was the result?
You still haven't answered:
  1. what board(s) are you using ?
  2. How, exactly, is it "corrupted" ?
  3. Have you used an oscilloscope and/or logic analyser to see what's happening on the wires?
  4. Have you tested & verified the stm32wb and stm32f407 separately?
Please see: How to write your question to maximize your chances to find a solution - the better the information you supply, the more likely you are to get a good & quick solution
