why 3.3v when u can 5000V
Jan 24, 2022 11:53 AM UTC
Trying to build freeRtos project with stm32u575zi (nucleo-u575zi-q), the freeRtos option not showing in the IOC file, I tried to download it and link to the project without success.... In the exemple project they use virtual file so i cant take it.
What needed to add freeRtos to the project ?
KnarfB
Jan 24, 2022 12:47 PM UTC
Not a full solution, but you might check here: https://github.com/FreeRTOS/lab-iot-reference-stm32u5
hth
KnarfB
David Littell
Senior II
Jan 24, 2022 2:09 PM UTC
Yeah, it's only been months and months and months...and more months. ST appears clearly focused on some new shiny BS thing instead.
KnarfB
Jan 26, 2022 10:03 AM UTC
My first experiences with ThreadX are not bad. Did you see the compatibility layers: https://github.com/STMicroelectronics/x-cube-azrtos-h7/tree/main/Middlewares/ST/threadx/utility/rtos_compatibility_layers. Its not U5, but should be a thin layer, easy to port.
hth
KnarfB
