AGaru
Oct 11, 2019 6:49 AM UTC
TIM5 CH4 PWM Output
Hi all,
i initialized the TIM5 CH4 PWM with the cube mx interface and then i used :
HAL_TIM_PWM_Start(&htim5, TIM_CHANNEL_4);
The output is supposed to be observed on PI0 - D5 on the CN4 on the back. There is nothing on the oscilloscope though. Do you know the reason? Thanks.
AGaru
AGaruBest answer
Oct 15, 2019 7:45 AM UTC
Hi, thank you.
I figured it out, i was just missing a parameter so the duty cycle was 0.
waclawek.jan
Oct 11, 2019 7:46 AM UTC
Is this a Disco or Nucleo board? Is there anything connected on that pin on the board?
Read out and check/post content of relevant GPIO and TIM registers.
AGaru
AGaruAuthorBest answer
Hi, thank you.
