Dec 12, 2024 2:15 AM UTC
TIM_BRK PWM shutdown
hi, im using stm32g474vet6 tim_bkin for pwm shutdown through external pin, when im normally using pwm only tim break interuppt is happening, pwm is shutting down
but if im using same timer in triggermode for another timer and pwm generation, tim_brk interruppt is not working, even the external interuppt signal itself not coming in irq handler and get flag also not coming.
what will be the reason any configuration issues.
configuration:
both the normal and complimentary pwm is enabled
ossi bit is set
timer break interuppt is enabled
external input pin is opendrain and pulldown mode
