Joe.H
Nov 17, 2021 5:18 PM UTC
STN32H747 Dual Core - only reset 1 core
I can perform a software system reset but what I want to do is have the M7 reset the M4 cpu - is there a way?
I have always written my own bootloader so the product can have firmware upgraded in the field.
With the Dual Core - the M7 will be updating the flash memory space for the M4 and I need to be able to have it start back at its reset vector.
Uwe Bonnes
Chief
Nov 17, 2021 8:31 PM UTC
Try SCB_AIRCR_VECTRESET
Dec 2, 2021 2:41 PM UTC
Hello @Joe.H​ ,
Did you tried the line suggested by @Uwe Bonnes​  ? If his proposal works, please mark the reply as Best answer (click on "Select as Best").
Imen
Joe.H
Joe.HAuthor
Dec 2, 2021 3:42 PM UTC
If I read the documentation properly - it states that CPU1 can software reset CPU1 and CPU2 can software reset CPU2. I do NOT believe that it states CPU1 can reset CPU2 via that process.
If my statement is correct - than it does not answer the question.
Thanks for trying.
Uwe Bonnes
Chief
Dec 3, 2021 1:28 PM UTC
I did not notice your request to reset the other CPU. I scanned RM0399 and did also not find anything.
