[stm32u585] HAL_IWDG_Init reconfig does not take effect
hello,
I encountered a problem while developing for stm32u585.
I change the iwdg reload value by HAL_IWDG_Init(), and then HAL_PWR_EnterSTANDBYMode(), but the new reload value does not take effect:
 hiwdg.Instance = IWDG;
 hiwdg.Init.Prescaler = IWDG_PRESCALER_64;
 hiwdg.Init.Window = 4095;
 hiwdg.Init.Reload = 3600;
 hiwdg.Init.EWI = 0;
 HAL_IWDG_Init(&hiwdg);
 HAL_IWDG_Refresh(&hiwdg);
 HAL_Delay(300); //more than one downcount
 HAL_PWR_EnterSTANDBYMode();
if delay before refresh, it seems work
 hiwdg.Init.EWI = 0;
Is this the correct process ? If I want to ensure the modification is successful, what should I pay attention to
Saket_OmBest answer
Hello @lll
after changing the IWDG prescaler/reload, the new configuration is not guaranteed to be fully effective if you enter STANDBY immediately. Even though HAL_IWDG_Init() waits for update flags, the IWDG (running on LSI in another clock domain) needs a short time to synchronize internally. Therefore, your second sequence is the correct approach: add a small delay after HAL_IWDG_Init() and before the first HAL_IWDG_Refresh() / HAL_PWR_EnterSTANDBYMode(), to ensure the new reload value is properly taken into account.
In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question. Saket_Om
Saket_OmBest answer
Hello @lll
lllAuthor
LSI=32K, prescaler=128 ==> IWDG=250Hz
before: prescaler=64, reload=40
after: prescaler=512, reload=3600
if i only config once, i need to delay about 3s. if i config twice, it seems that only a delay of 300ms is needed:
 hiwdg.Init.EWI = 0;
 HAL_Delay(350);
 hiwdg.Init.Prescaler = IWDG_PRESCALER_512;
 hiwdg.Init.EWI = 0;
is this sequence correct?
