STM32U575xx USBX CDC ACM only transmits less than 8 bytes
I am having issues with transmitting more than 8 bytes of data. If I transmit 12345678 everything works and I can see the data on my serial monitor. However if I transmit 123456789, then I do not get anything on the serial monitor. I have enabled the ZLP define and commented it out but still no lock. What am I not setting correctly here?
