Apr 22, 2026 21:08 UTC
STM32N6750-DK SD card boot procedure
Hello, is it possible to boot FSBL and load application from SD card upon powerup, bypassing onboard flash?  I didn't see any clear guides on this procedure.
Thank you
Apr 23, 2026 09:31 UTC
Hello @Cococarbine
Please refer to the article below. This article provides a quick tutorial on how to use the FSBL to copy the application from an external serial NOR FLASH to an external serial PSRAM.
How to execute code from the external PSRAM using ... - STMicroelectronics Community
In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question. Saket_Om
