chemax
Jan 30, 2019 10:46 AM UTC
STM32L4R5xx SVD file error
I try to see value in DMA and DMAMUX registers, but I don't find it in svd files. Although, there is a description for DMA, but it is not correct as according to the RM there is no register DMA_CSEL in DMA, however, it is described in the SVD file.
the module DMAMUX with register description is completely missing.
Feb 1, 2019 8:45 AM UTC
Hello @chemax​ ,
We raised this issue internally for check and fix.
Thank you for your contribution.
Kind Regards,
Imen
chemax
chemaxAuthor
Mar 1, 2019 7:44 AM UTC
Good day, Imen
I understand that you have a lot of work, but still I would like to know:
A month has passed since my question about the content of errors in the SVD files of the STM32L4+ series. What is the progress on this issue?
We also found discrepancies in the description of the register of timers in the SVD and the reference's manual.
There is also a fear that the file with the register description stm32l4xx.h may contain errors, since it is generated on the basis of the SVD files.
Best regards,
Maxim
chemax
chemaxAuthor
Feb 1, 2019 9:41 AM UTC
Thank you too.
I assume that the error has crept in for the whole family of L4+. I opened the following files: stm32l4r5.svd, stm32l4r7.svd, stm32l4r9.svd and did a search for the word "DMAMUX".
Kind Regards,
Max
