TNguy.10
STM32L4 USB CDC Device
  • April 16, 2020
  • 0 replies
  • 558 views
Dear,
I have an issue working with STM32L4 USB CDC Device. So I have two separate projects of this. I configure USB CDC Device on the first prooject (COM6), and everything works fine. I then work on another project with a different configure on USB CDC Device (COM7), and it works fine. The problem is now, I load the first project and USB is detected as the COM7 from the second project (supposed to be COM6 as normal). What should I check, Thank you?
Best,
Tony
